DropboxConnector upload size limit?
  • July 14, 2022
  • 10 views
braggken
Hi folks,
I am getting some obscure errors (Dropbox API I assume) using the DropboxConnector with bigish files >300 mb.
Looking at the error and the Dropbox community I am assuming FME is using the /2/files/upload endpoint which is limited to 300 mb. Can anyone confirm there is an upload size limit with the DropBoxConnector? Workaround?
Best answer by danminneyatsaf
Hi @braggken​ you're correct, the DropboxConnector is capable of uploading files up to 350mb in size as per this documentation here: https://help.dropbox.com/installs-integrations/sync-uploads/upload-limitations#:~:text=If%20you%20are%20over%20your,must%20be%20350GB%20or%20smaller.
You may be able to workaround this by using creating your own API calls that use an Upload Session, which as a 350GB file size limit:
https://www.dropbox.com/developers/documentation/http/documentation#files-upload_session-start
https://www.dropbox.com/developers/documentation/http/documentation#files-upload_session-append
https://www.dropbox.com/developers/documentation/http/documentation#files-upload_session-finish
Hope this helps!
- Dan M
danminneyatsaf
Forum|alt.badge.img+12
Hope this helps!
- Dan M
