How to slope a 3D solid ?
Hello Community,
I have a 2D line that was converted to 3D (solid). I need to 3D line (solid) to slope upwards or downward.
Any suggestion(s) on how to do that ? I try the 3D interpolator, but it does not do anything.
Thank you,
David
jneujens
  • May 11, 2018
It should do something.
When you are checking your output, does the line contain z-coordinates?
If you are looking at your line in Data Inspector, then don't forget to click on the button to enable 3D viewing. Otherwise, you will notice a difference.
The 3D line (solid) does have Z value.
Problem solved.
The 3D_Interpolator needs to be run on the 3D line before the line is converted into a 3D line (solid)
jneujens
  • May 11, 2018
davidalvarez76 wrote:
Problem solved.
testinterpolator.fmwIt does not really. In this example the 3DInterpolator works on a 2D line and makes it a 3D line. An example is attached in this comment.
Problem solved.
Thank you for the example. Now I understand better the transformer.
