Electric Migration workspace for Electric Asset Package V3.2 Translation Failure
  • March 3, 2020
  • 9 views
Hello Everyone,
I am trying to run the translation on the Electric Migration workspace for Electric Asset Package V3.2 (Electric Migration V3 2019_12_18.fmwt file) using FME Desktop version 2019.2.3.1. It fails because it is missing a file called "NapervilleElectric_2019_10_22.gdb.zip". Is the file available for download, and is the workspace supposed to produce an asset package that is ready to load into a Utility Network without further configuration?
Best answer by markatsafe
@phoolish_one The Naperville dataset is supplied with the asset package that you down load with the Utility Network Package Tools.
Our FME Utility Network migration training sessions are a good place to start: https://knowledge.safe.com/articles/73939/fme-training-course-for-esri-utility-network-migra.html Link to the course recordings are at the top and some of the course materials towards the bottom. You probably only need to flick thru the day 3 & 4 sessions if you are familiar with FME.
  • March 4, 2020
