Released
oAuth Support in FME Server
Related products:FME Flow
siennaatsafe
fmelizard
danilo_fme
sigtill
bruceharold
+6
  • siennaatsafe
    siennaatsafe
  • fmelizard
    fmelizard
  • danilo_fme
    danilo_fme
  • sigtill
    sigtill
  • bruceharold
    bruceharold
  • panda
    panda
  • james_rutter
  • geolassi
    geolassi
  • afavaccio
    afavaccio
  • lpalli
  • colinhenderson
    colinhenderson
fmelizard
bruceharold
Forum|alt.badge.img+17
  • August 2, 2016
If you're going down the generic API route then this is a must - got to generate those tokens.
LizAtSafe
Forum|alt.badge.img+15
  • June 15, 2024
https://support.safe.com/s/article/configuring-fme-server-to-use-oauth-based-web-conn
