Lookup table to find nearest smallest value
Hello!
I have two tables:
Table 1:
NameBasevalueaaa0bbb0bbb5bbb11ccc0
Table 2:
NameValuebbb3bbb8bbb10ccc8
Now I want to get for each feature from table 2 the nearest smaller 'Basevalue' from table 1 compared to the 'Value' of table 2.
The Result should look like this:
NameValueResultValuebbb30bbb85bbb105ccc80
Any ideas how to do so?
Greetings
Stefan
  • June 5, 2020
Hi @ferorelatum, this screenshot illustrates a possible way to do that.
  • June 5, 2020
Another thought. The ListElementFilter is a custom transformer from the FME Hub.
Forum|alt.badge.img+32
  • June 5, 2020
The Inline Querier is another option
select t1.Name, t1.Valuemax(t1.Basevalue) as ResultValue from (select *
    from "Sheet2" s2,
    "Sheet1" s1
    where s2."Value" >= s1."Basevalue"
    and s2.Name = s1.Name) t1
    group by t1.Name, t1.Value
find_nearest_below.fmwt
@takashi @ebygomm thanks a lot! Both of your options works fine!
