How to set up/configure Active Directory Windows Authetication for FME Desktop (for access to MSSQL databases)?
When attempting to connect to MSSQL Non-Spatial schema with Windows Authentication, I receive the following error: "Microsoft SQL Server <Non->Spatial Reader: Connection Failed. Connection string 'Provider=SQLNCLI11;DataTypeCompatibility=80;DataSource=<server>\\<iinstance>;User ID=;Password=*********',Provider error '(2147467259) Named Pipes Provider: Could not open a connection to SQL Server [2].'
Due to database security policy I need to use Windows and not SQL Server Authentication.
I am able to access the database with SQL Server Management Studio using Windows Authentication, and have checked server and db name are correct.
In the error message, the Windows 'UserID' value appears to be empty, does this mean I need to configure the AD user with FME? If so could someone explain how or refer me to instructions? Thank you.
stalknecht
Forum|alt.badge.img+19
  • August 2, 2018
When adding the reader or writer choose windows authentication. See screenshot:
  • August 2, 2018
I do this, but I am unable to connect to tables or schemas and receive error above.
stalknecht
  • August 3, 2018
@c_geraci , did you try both JDBC and or ADO and which one do you use?
