I would like to write several sheets into an excel file: on every single sheet there should be data and a chart based on one of the columns. I have tryed it using a template file which already has a chart on the template sheet. I am already using a template file and a template sheet.
On the output file i just get data on every single sheet which is perfect, but only get a chart on the first sheet. The chart is based in one of the columns.
Any clue on how to get an automatic chart per sheet?
