How to create a shape depends on coordinates
  • April 14, 2020
  • 10 views
i have x minimum ,y minimum
x maximum and y maximum
how could i create a shape ,it should be sqaure depends on the coordinate
i tried to do by vertex creator then line builder ,i found all points that has this coordinates connected with lines to each other ,
could some one give me suggestion,what should i do
Thanks alot
Best answer by ebygomm
You should be able to use those attributes in a 2DBoxReplacer
Forum|alt.badge.img+31
  • April 14, 2020
