Can't see how I can re-order.
Any ideas? Am I doing summat wrong.
Best answer by ebygomm
Should read
I know in FME 2012 desktop the csv reader only reads the first 9 columns (col0 - col8) in a LPG/LSG type file as the first line is only 9 columns long. With it being col9 that's the issue, i.e. column number 10, I wonder if this is a similar issue?
