Create a jp2 with a tif (with an inferior size)
Hello,
I would like to do a jp2000 file with a tif.
My conditions :
1- the tif is black on white so i want my jp2 black on white
2- the siz of the jp2 must be less than the tif
Using rasterpalletremover my jp2 is 500Ko big but i need to specify nodata=0 in Qgis to see it in black on white instead of white on black..
See joined files (fil and jp2 500 Ko).
I test many ways like rasterpaletteresolver and the viewing is ok but the files is three times bigger!!!(2.9Mo).
If anyone can help me
thanks,
dowload my file here :
https://drive.google.com/file/d/0B90n7rx5ph0ZMXFUUUtvbVplUXM/view?usp=sharing
PS : si vous parlez français dites le moi!!
Forum|alt.badge.img+19
  • December 5, 2014
The original tiff is a 2-values image (0=white, 1=black).
If a 2-values image (0=black, 1=white) satisfies your requirement, you can reverse all the cell values with the RasterExpressionEvaluator after removing the palette.
Expression: @if(A[0]==0,1,0)
Then, write the raster into jp2 (0% compression).
Takashi
  • December 6, 2014
"2-values image" was not general terminology. I intended to mean "Binary image". (http://en.wikipedia.org/wiki/Binary_image)
