Hello!
I generated a CityGML building model from an fbx model. The model could be opened in FZKViewer but the view is very strange. I could see the textures in the back when I am on the front view. It is like the surface in front of me becomes a very transparent glass.
This happens at all of the sides of the model except the roof and ground surface. When I turn off the texture, everything is back to normal.
Is it the problem of the texture? How could I check if it is on the texture and how could it be fixed?
