QGIS python library not able to load
  • November 19, 2024
  • 64 views
spalrobert
I am trying to run a custom python code that uses QGIS library in PythonCreator. However when I run the code I get this error:
Python Exception <ImportError>: DLL load failed while importing _core: The specified procedure could not be found.
I tried everything, I followed the documentation/manual how to setup custom python interpreter, I tried to setup dependencies and environment variables but none of that worked. Can someone tell me what am I doing wrong? Thanks!
evieatsafe
Forum|alt.badge.img+20
  • November 22, 2024
Hi ​@spalrobert a colleague mentioned that this is likely due to the Python interpreters' ability to find the correct dependencies required by the library you are using. Perhaps try comparing the paths from your QGIS environment and in FME. (assuming that this works in QGIS)
import sys
print(sys.path)
Add any paths that are present in QGIS but not FME.
sys.path.append(r"<missingPaths>")
Let us know if this returns different results.
spalrobert
  • November 28, 2024
Hi ​@evieatsafe print(sys.path) results in:
['C:\\Program Files\\FME\\FME2024_1\\python', 'C:\\Program Files\\FME\\FME2024_1\\python\\python312', 'C:\\Program Files\\FME\\FME2024_1\\python\\fme-plugins-py312.zip', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\python312.zip', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\DLLs', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib', 'C:\\Program Files\\FME\\FME2024_1', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib\\site-packages', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib\\site-packages\\win32', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib\\site-packages\\win32\\lib', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib\\site-packages\\Pythonwin', 'C:\\Program Files\\FME\\FME2024_1\\plugins', 'C:\\Users\\fa08119\\HCP\\Documents\\FME\\Plugins\\Python', 'C:\\Users\\fa08119\\HCP\\Skrivbord']
I am not sure what to do with the second command - sys.path.append….
