Create property in custom transformer
mr_fme
Forum|alt.badge.img+8
I would like to create the option to pass a value by attribute.
How can I create it in a custom transformer like in the image below?
Thanks
Best answer by hkingsbury
In your custom transformer, creating a parameter will then expose a field on the custom transformer that will allow you to pass through the value of an attribute.
See here: https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/custom_transformer_creating.htm
hkingsbury
Forum|alt.badge.img+53
  • July 28, 2024
mr_fme
  • July 29, 2024
Thanks @hkingsbury
