Hi FME community.
I would like to merge two columns value in once like that :
Col1Col2AZERTYHELPAZERTYNOBODYQWERTYENJOY>
Col1AZERTYQWERTYHELPNOBODYENJOYCan I do that with a transformer ?
Thank you.
Hi FME community.
Thank you.
Best answer by takashi
Hi @lalandexavier, if i understand your requirement correctly, this workflow might help you.
