Feature writer transformer does not expose all writer parameters. I'm passing fme_db_operator to it with the value of update, but it tries to insert. In the past I have been better able to troubleshoot with bulk insert off (it's on by default), but I can't find it to turn it off. Is that because it's not exposed?
