Why does my AutoCad reader turn a single text object into 2 distinct rows if it contains a space character? I would assume that my reader would output just 1 row with autocad_text_string = '1-500 EE'.
  • May 6, 2021
  • 5 views
fimpe001
Participant
The ACAD reader has a lot of settings that you can tweak. Have you tried disabling this check box:
acad mtextIt will prevent FME from splitting multi-line text entities into separate features.
More info in the documentation: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/acad/ACAD_reader.htm
