I have 18 polygons in a database. I want to retrieve the x and y value of each CenterPoint of the shorter side of each polygon (approximately where the red dot is on image). I also want to create a new attribute called sequence. The first polygon on the left should get the value 1, the second value 2, the third one value 3 and so on. How can I achieve this ?
