.las into Cesium3Dtiles conversion
Hello,
I have a question regarding the conversion of .las files into Cesium3Dtiles with FME2017. The goal is to convert .las files (EPSG: 31256) into Cesium3Dtiles (EPSG:4326) including an offset of z = 156.68 m. Furthermore, the bounding volume type of the Cesium3Dtiles should be given as a bounding region (six numbers) with coordinates in degree instead of a bounding box (12 coordinates) in radians. Converting the .las file into the cesium3Dtiles with the mentioned reprojection doesn`t seem to be the problem. However. I do not know how to convert the output, which automatically creates a bounding box with coordinates in degrees, into a bounding region in radians.
  • July 22, 2019
@markatsafe @mark2atsafe @takashi @lenaatsafe
virtualcitymatt
Forum|alt.badge.img+34
HI @karow,
I suspect that this if something which you can not change until the writer get some more Development done to it. Is there anyway you can adjust your Cesium application to work with the FME output?
