hi,
I want to import DXF data into Smallworld by using FME. I have bellow doubts in exporting. When i try to add reader in "Reader Gallery"i found 5 type of "*,dxf,.dwg" formats.
First i try to select "Esri Mapping Specification for CAD(MSC)" data in DXF file not visible. After that i tried with "Autodesk AutoCAD DWG/DXF" it displays layers from DXF source file but fields are not visible in work bench.
I checked the dxf file in ESRI they have fields and values. But in FME those values are not populated in workbench for mapping.
"Layer,Color,Linetype,Elevation,LineWt,RefName,Angle" are the fields in layers. But these fields are not visible in FME workbench.
Can any one tell me how to import DXF file data into Samllword by using FME.
Please advise if I am missing something. Or how would I resolve this issue.
Thanks in advance for your help.
