FME KML file name (bit strange behavior)
  • September 19, 2014
  • 14 views
Hello,
I have observed that FME behaves differently if we run a workspace in Workbench and after publishing to server.
I have a workspace with Shape Reader reads multiple files and converts to KML using GENERIC writer. If I fanout the dataset on fme_basename it works perfectly in workbench, but if same workspace is published to server and run as service it creates output kml as "output.kml"
e.g. Shape reader reads Test1.shp & Test2,shp
Creates output by fanning out on fme_basename
Output KML : Workbench creates Test1.kml in Test1 folder & Test2.kml in Test2 folder - PERFECT
On server : "output.kml" in Test1 folder and "output.kml" in Test2 folder
Could anybody explain this behavior?
Cheers
John
davideagle
Forum|alt.badge.img+21
  • October 6, 2014
Thats because as a file based format, KML in the Generic Writer gives you the option to set the file name in the Server interface. You'll need to either set that in the interface of Server, disable it or prepare and set the file name in the Workspace itself.
