FeatureReader to be used for Copy from Reader
geolassi
Forum|alt.badge.img+5
Hi! I'm using FeatureReaders in my workspace, and when adding a Writer, I would like to use Copy from Reader option to get the feature types and their attributes to the Writer, but I can't because it seems Copy from Reader works only for Readers. Am I missing something, or is it not supported yet?
Also I can't get the attribute types and lengths from an FeatureReader (Copy Attributes From Transformer), and I need to have a Reader, copy attributes from its feature type.
mygis
Forum|alt.badge.img+13
  • June 5, 2017
Hi @geolassi (Lassi), do you need to do that dynamically?
geolassi
  • June 5, 2017
Hi @gisinnovationsb, not dynamically, but with a static schema.
mygis
  • June 5, 2017
Lassi, why don't you try to cheat your way out by writing the data, adding a reader (disabled) with the intermediary data then copying the attributes into the new writer...
Lyes.
mygis
  • June 5, 2017
Hi Lassi ( @geolassi), please check out this video https://youtu.be/QgUbE_6FPVE
I did it with a FeatureWriter but it works with the FeatureReader too.
mark2atsafe
Forum|alt.badge.img+44
I think a request for that is filed as PR#69977. I've added a link to this thread and increased the priority, but it would still be useful if you posted this as an Idea for other users to vote on.
geolassi
  • June 16, 2017
Lyes.
Yes, I'm doing that, but I don't like cheating :D.
