sde geodatabase holds multipolygon and polygon
  • June 13, 2014
  • 7 views
Using generate workspace in FME Desktop.
Using Oracle/SDE as reader source, and file geodatabase as writer target.
I want to copy feature datasets and features from sde to file geodatabase.  Because some feature classes have multipolygon and polygon features , a geometry filter is automatically put in and splits to 2 newly named feature classes. Even if template is used it does this.   Is there anyway to turn this automatic geometry filter off, so the copy happens just like ArcCatalog, 1 for 1?
Best answer by gil
Resolved by not using generate workspace and individually creating reader and writer.  Reader feature datatypes were duplicated to writer using a xml workspace document.
  • June 13, 2014
