Using Excel writer after Excel styler get no output ,Why
gogopotter90
Forum|alt.badge.img+13
Hi Guys,
i am wondering of using of Excel styler ,
if i select for my excel writer this option
Output Field Names: No
Use Attribute Names As Column Positions: Yes
i can see my result only in inspector but it does not exist any excel file ,my folder is empty .
so i tried to put my excel writer before excel styler so i can get my excel output in the folder .
then i put again my excel writer after excel styler but i changed in parameter of excel writer as try , this option
Output Field Names: yes
Use Attribute Names As Column Positions: No
i found i can get my output in the folder nd everything is perfect except the first row it has field names ,i want to delete it .
So why using this option as No ,i got nothing
or if someone know a method to delte the first row so everything will be fine with me
Best answer by ebygomm
Try
Use Attribute Names as Column Positions: No
Forum|alt.badge.img+32
  • February 17, 2020
Try
gogopotter90
ebygomm wrote:
Try
thanks alot it is working perfect .
gogopotter90
ebygomm wrote:
Try
do u know ,why sometimes when i want to change background colour for word in attribute .sometimes it works with me in some attributes and some attributes does not work .what should i look for ,i tried to copy the word so it should be the same and no difference but no success
