When I use FME Quick Translator to convert CityGML file to IMX, I get this error. How can I fix it?
Error on conversion of CityGML file to IMX
Best answer by nathanatsafe
Hi @alialaghbandrad, thanks for posting your question!
It sounds like there is some issue regarding your log file or its location. Do you have permissions to write to the directory you've set? Does the directory already exist? Will the translation run if you choose to write to another directory?
Hope this helps troubleshoot the issue.
Best,
Nathan
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
