Hi all,
question please regarding "SOURCE_DATASET" value.
My custom reader has its own dataset parameter, SB_DATASET.
I need to sync SB_DATASET with SOURCE_DATASET: SOURCE_DATASET <-> SB_DATASET
The following way doesn't work:
SOURCE_SETTINGS
DEFAULT_VALUE SB_DATASET $(SB_DATASET)
GUI TEXT SB_DATASET Dataset Name:
END_SOURCE_SETTINGS
SOURCE_DATASET $(SB_DATASET)
when IFMEReader::open(const char* datasetName,
const IFMEStringArray& parameters) - is called - the datasetName is "."
The opposite doesn't work as well:
SOURCE_SETTINGS
DEFAULT_VALUE SB_DATASET $(SOURCE_DATASET)
--------OR-------->
DEFAULT_VALUE SB_DATASET $[SourceDataset]
END_SOURCE_SETTINGS
SOURCE_DATASET \"$[SourceDataset]\"
After creating the reader - SB_DATASET has "$[SourceDataset]" or empty value.
Any ideas how to sync these two variables will be very appreciated.
Thanks!
