Group points spatially and calculate their average positions
I have a few hundreds of points and I'm trying to:
1) 'Cluster' them spatially (max distance 25cm) and based on one common attribute while the number of neighbors can vary from 0 to 5
2) Calculate average position for each 'cluster' of points and replace their geometry so that all aggregated points have the same position (of course keeping the original attributes).
I would be grateful for a hint, I've been trying different transformers and I can't find a solution.
Best answer by erik_jan
1) NeighborhoodAggregator generates the groups
2) CenterpointExtractor calculates the X and Y of the center point of the group
VertexCreator replaces the geometry by a point using the X and Y
erik_jan
Forum|alt.badge.img+17
  • January 8, 2018
  • January 8, 2018
Hi @erik_jan,
thanks for your reply! I tried NeighbourhoodAggregator, but from there I had to work with lists if I wanted to keep all attributes (is that correct?). This is where I got stuck, I didn't know how to handle the lists and extract centerpoints. Is it possible?
erik_jan
  • January 8, 2018
kajciuk wrote:
Hi @erik_jan,
You can use the ListExploder after the CenterpointExtractor to create the individual objects (including the calculated X and Y and the original attributes).
  • January 8, 2018
This was indeed my missing element! Thank you
