Is FME's DWG Reader able to determine DWGUNITS setting of a given DWG?
  • July 5, 2016
  • 11 views
I successfully read autocad_insunits (Format Attribute) for any given DWG (In Autocad, this is the INSUNITS setting).
Is it also possible to determine the DWGUNITS setting for any given DWG? I believe that I have tried all of the Format Attributes, with the word unit in the string, in FME 20160516 - Build 16494 - WIN64.
Thanks.
gabriel_hirsch
Forum|alt.badge.img+11
No. Just the INSUNITS setting can be retrieved right now.
