convert points to polygons based on an attribute
i need to convert points to polygons. the points witch belong to the same polygon have the same id_parcel.i need to find a way to generate polygons based on this identifient(id_parcel)
fmelizard
Forum|alt.badge.img+17
  • July 31, 2017
Hi @nazlii. A suggested approach to get you started:
1) Use reader or VertexCreator to make points
2) Use Sorter to sort by attribute
3) LineBuilder next to create polygons, setting Connection Break Attribute to your attribute
Forum|alt.badge.img+21
  • July 31, 2017
additional to the procedure above, probably you will have to close the resulting line with the LineCloser to make a polygon.
erik_jan
  • July 31, 2017
Also, have a look at the discussion in this similar item:
issue-with-converting-points-to-polygon
