Extract and Calculate Overlaying areas
Hello everyone,
I've got a certain problem that I can't solve for many days.
I'm trying to find the overlaying areas between an IFC file and an ACAD one.
I explain the idea, the purpose is that I've got 2 readers as entries : one for IFC and one for ACAD. then the we need to find the spatial relation between each objects of the IFC and the zones drawn in ACAD. --That point is OK.
Then for the objects which have 2 _related_candidates, I would like to calculate the overlaying area with each zone to keep only the one with the biggest overlaying area.
My problem right now is about that second step that I can't solve for the moment.
I hope it's clear enough and you'll be able to help me with this matter.
Regards,
Clem
Best answer by jonas_nelson
Hi @clem_lx
I think something like this should work. (I've used it to create a hexagon map where I wanted to populate the hexagon with only the dominant landuse in the hex).
In my workspace, I put the Counter on the hexagons, so that for each hexagon, I kept the most dominant landuse. In your case, maybe you want to look at each IFC surface and keep the dominant ACAD area - or the other way around.
antoine
Forum|alt.badge.img+5
  • November 26, 2019
Maybe you need to project your surfaces if they are 3d. Have you tried SurfaceFootprintReplacer?
  • November 26, 2019
antoine wrote:
Hey,I'm working only with footprints to compare some 3D objects with a 2D zoning.
The matter is how to extract some geometries under conditions in order then to calculate the overlaying areas.
jonas_nelson
Forum|alt.badge.img+19
  • November 26, 2019
Hi @clem_lx
  • November 26, 2019
jonas_nelson wrote:
Hi @clem_lx
Thanks for the tip, I'll try it and comme back with some news
