I'm trying to create point feature class in File Geodatabase. I'm getting an error when I try to write to a file geodatabase: An error occurred while attempting to convert the '' component of a date....
  • December 21, 2022
  • 72 views
I'm able to create a point shapefile successfully.
ctredinnick
Forum|alt.badge.img+18
  • December 22, 2022
I get that sometimes when reading data from SDE, writing to file GDB. A workaround is to add a AttributeTrimmer on the date attributes, which will remove any invalid chars, reset encoding, whatever the actual issue is.
  • December 23, 2022
@ctredinnick​ Thanks mate, this was a big help.
fchevaillier
Participant
@ctredinnick and @robeesafe I am getting the same error, but the AttributeTrimmer is not resolving it. Any other ideas?
