Can you explain a little more?
The shortest distance between two points is a line. The VertexCreator can do that.
Building a Surface from points can be done using the SurfaceModeler transformer..
15 votes
10 votes
9 votes
7 votes
5 votes
4 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
