Connect lines without common ID by order in file
Hi
I have a csv file with lines that relate to each other purely by the order they appear in the file. So all the records with a record type "1" are the main record and the lines below with 2, 3, 4 or 5 record types relate the record above with the type 1. There could be any number of lines below and you only know when you get to a new record because you get a new record type 1. I would like to assign a new field with a common ID to the lines that refer to the same property. So in the first example the 8 lines would have a common ID and then the next 3 lines a different ID.
1 106 London road
2 Ground
2 Ground
2 First
1 104 London Road
2 Stores
3 Offices
1 Retail
4 Car Parking
Any help gratefully received.
Thanks
Ruth
Sorry my example didn't follow what I said. I posted an image but this disappeared. Basically I want to connect the first 4 lines together. The next 3 and the finally 2. Thanks!
jdh
Forum|alt.badge.img+28
  • March 1, 2018
You can use the adjacent features to assign an id, that increments when you get to a record 1.
textlinebreaks.fmw
