Set appearance of multiple geometries.
  • March 23, 2021
  • 13 views
Hi!
I have problems with setting the appearance of multiple geometry instances in FME.
For instance: I have N appearances with different names and want to match them with M geometries. The material with the name A(Style name) should match with the geometry with the name A (geometry Name).
I cannot figure it out how this is done with the appearance setter. Anyone have an idea?
Best regards,
Adam
caracadrian
Forum|alt.badge.img+22
  • March 23, 2021
Use GroupBy procesing in AppearanceSetter. The attribute name of the appearance should match the attribute name of the geometry (use GeometryPropertyExtractor)
