Error from Fme Server Notifier
Hello I am using FME Server Notifier in my workbench . The topic is subscribed to email .
But it is throwing below
BODY @EvaluateExpression(STRING_ENCODED,<at>Value<openparen>_job_id<closeparen><lf><at>Value<openparen>_timeStarted<closeparen><lf><at>Value<openparen>_timeFinished<closeparen><lf>,FMEServerNotifier_2) OUTPUT OUTPUT FEATURE_TYPE FMEServerNotifier_2_OUTPUT OUTPUT REJECTED FEATURE_TYPE FMEServerNotifier_2_<REJECTED>' is incorrect.  The parameter to TOPIC must be a constant value, a value-of (&) attribute, or an FME function call
Below is my content for the notification
@Value(_job_id)
@Value(_timeStarted)
@Value(_timeFinished)
Any ideas why this might be happening ?
  • July 22, 2014
What's the name of the topic? I wonder if it has special characters in it that are causing problems? That's my first guess.
Mark
  • July 22, 2014
Roll_Back_Load is my topic name
Subscription  name is Roll Back Load
  • July 23, 2014
Hi Vikram
I looked into this a bit more and I believe it is an issue that is now fixed. The fix is in FME 2014-SP2 and (of course) FME 2015 beta. If you can upgrade to one of those versions then that should resolve the problem.
If you have further problems with this, please do contact our support team (http://www.safe.com/support) and mention PR#52539
Hope this helps
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc
