FME Server engine cannot connect to remote host
I have FME Server running on Machine A. (Engine within this docker compose is working)
Now I want to have my engines running on a different machine.
I've setup the following docker compose on Machine B (Engine host)
version: '3.2'
services:
  fmeserverengine:
    user: 0:1363
    image: quay.io/safesoftware/fmeserver-engine:2019.0.1-20190506
    volumes:
      - '/fmeserverdata:/data/fmeserverdata'
    restart: always
    environment:
      - EXTERNALHOSTNAME=${FME_HOST}
      - EXTERNALPORT=${FME_PORT}
      - WEBPROTOCOL=${FME_PROT}
    hostname: fme-enginserver-engine-1
    extra_hosts:
      - "fmeserverdb:${FME_HOST_IP}"
      - "fmeservercore:${FME_HOST_IP}"
In addition, I mounted the /data/fmeserverdata from Machine A, on Machine B (/fmeserverdata).
When I start the engine container on Machine B, I can see the logs from Machine B using the webinterface on Machine A. (/resources/logs)
However, When I spin up the container, the only error I see is the following:
FME 2019.0.1.0 (20190506 - Build 19253 - linux-x64)
        FME Engine (node locked-crc)
Machine host name is: fme-enginserver-engine-1
Operating System: Ubuntu 16.04.6 LTS (Xenial Xerus)
Copyright (c) 1994 - 2019, Safe Software Inc.
            Safe Software Inc.
FME_SHARED_RESOURCE_DIR is unset
FME_SHARED_RESOURCE_DIR has been changed and is now '/data/fmeserverdata/resources/engine'
Could not establish connection to host
Program Terminating
Translation FAILED.
This error keeps repeating untill I shutdown the container, which is also required to access the web interface again because somehow as long as the engine container on Machine B is running, the server core container on Machine A becomes irresponsive.
I need some advice on either how to debug why it can't connect, or how to solve it alltogether.
Thank you in advance!
Forum|alt.badge.img+49
There's some general troubleshooting topics related to FME Server here: FME Server Troubleshooting
  • June 21, 2019
I’ve been there, but I’m either not seeing it, or my problem isn’t listed.
  • June 21, 2019
I’ve found that the server core opens up a random port for the engine to connect to;
INFORM : Registering FME Engine...
INFORM : Transaction port 37629 opened for FME Engine communication
ERROR : No message length returned in FME Engine response
It’s unable for the engine to connect to this because the ports have to be pre-defined.
Is there a way to set a port-range for the Transactions that I can map in my docker-compose file?
  • June 21, 2019
Turns out I can set the
PORTPOOL
variable in docker compose, my problem is now solved.
  • February 23, 2022
I am in the same situation, I have set the PORTPOOL but it still doesn't work.
