I have a large table with 80 columns and 10 million records already in a postgres database. Most of the data is really numbers there are some NAs where an external process encountered blanks in the dataset. I want to convert the data table to numeric format and to do that I need to get rid of the NA values, any suggestions on the transformer and whether I need to apply this to all fields one at time? I was thinking of using the Attribute Calculator.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
