Accents in attributes
  • April 4, 2013
  • 24 replies
  • 520 views
Is there an easy way to remove accents from characters that are contained in an attribute?
fmelizard
Forum|alt.badge.img+21
  • April 4, 2013
The string searcher or the string pair replacer are a few options to consider.
sigtill
Forum|alt.badge.img+25
  • April 4, 2013
All Transformers under the Category: Strings will be worth a look:
  • April 4, 2013
here is a more dynamic solution using a PythonCaller. Modify "attribute_list" (line 16, case sensitive) to include the names of the attributes you want to be checked for accents:
import fmeobjects import unicodedata as ud   def rmdiacritics(char):     '''     Return the base character of char, by "removing" any     diacritics like accents or curls and strokes and the like.     '''     desc = ud.name(unicode(char))     cutoff = desc.find(' WITH ')     if cutoff != -1:         desc = desc[:cutoff]     return ud.lookup(desc)      def removeAccents(feature):     attribute_list = ("name", "type", "state")     for attrib in feature.getAllAttributeNames():         if attrib in attribute_list:             value = feature.getAttribute(attrib)             if value:                 value = unicode(value)                 new_value = ''.join([rmdiacritics(char) for char in value])                 feature.setAttribute(attrib, new_value)
You can also download the code here, in case the forum mangles the indents.
Example values before the PythonCaller:
Attribute(encoded: utf-8): `name' has value `François' Attribute(encoded: utf-8): `state' has value `Tørst' Attribute(encoded: utf-8): `type' has value `Salé'
After the PythonCaller:
Attribute(encoded: utf-16): `name' has value `Francois' Attribute(encoded: utf-16): `state' has value `Torst' Attribute(encoded: utf-16): `type' has value `Sale'   David
  • April 4, 2013
import fmeobjects
    if cutoff != -1:
    attribute_list = ("name", "type", "state") # Modify as needed
            if value:
  • Attribute(encoded: utf-8): `name' has value `François'
  • Attribute(encoded: utf-8): `state' has value `Tørst'
  •   Attribute(encoded: utf-8): `type' has value `Salé'
  • Attribute(encoded: utf-16): `name' has value `Francois'
  • Attribute(encoded: utf-16): `state' has value `Torst'
  • Attribute(encoded: utf-16): `type' has value `Sale'
  • April 4, 2013
Thank David.
THis is exactly what i am looking for.  However i am new with python scripts, and still stuck in FME2011 so it looks like this code will work with 2012.  Any suggestions on how to implement in 2011?
Thanks!
  • April 4, 2013
seems like a good opportunity to learn some Python, then :-)
Basically, replace
  • "fmeobjects" with "pyfme"
  • "getAttribute" with "getUnicodeString"
  • "setAttribute" with "setUnicodeString"
Untested, but I think that should be enough to get it running, I hope.
Also, take a look at the pyfme API doc in <fmedir>\\\\fmeobjects\\python\\apidocs\\index.html -- in particular the methods under FMEFeature.
David
  • April 4, 2013
Thanks again.  yes agreed i need to learn this part of FME.
One last (and probably dumb) question.  What symbol is used in the caller?
  • April 4, 2013
not a dumb question when you're not familiar with the PythonCaller :-)
You should use "removeAccents" for the PythonCaller.
Hint: it's almost always the function ("def ...") that takes a parameter called "feature", which represents each feature object passed into the function. E.g.
def <name of function>(feature):
David
  • April 4, 2013
I use StringPairReplacer like this
Source Attribute: Name
Replacement Pairs: É E È E Ë E Ê E Ô O Ç C Â A ï I î I
Result Attributer: Name2
  • April 4, 2013
Hi Steph,
I agree, that is the most "native" FME solution, but it assumes that you're able to populate it with all the possible variants. If something isn't caught (like a sudden "Û" in your example), it will simply pass through and result in an error further down the line, where it might not be obvious what happened.
The beauty of the PythonCaller script is that it is a lot more future-proof, although it adds quite a bit of complexity, I must admit...
David
  • April 5, 2013
Thanks all for the responses.   Agree that the native solution is probably the mosre proper, however my issue is that i do know all the possible input  scenerios i may run into.  The python script worked great.   With that said, i have never used the stringpairreplacer so it is good to see how this one works as well.
jeff_konnen
Participant
  • Participant
  • April 5, 2013
This function could be used in a PythonCaller:
 import unicodedata def remove_accents(input_str):     nkfd_form = unicodedata.normalize('NFKD', unicode(input_str))     only_ascii = nkfd_form.encode('ASCII', 'ignore')     return only_ascii
fme4ever
  • January 27, 2016
import fmeobjects
    if cutoff != -1:
            if value:
Thanks David, that solution is just awesome! I used it via a Python Caller and it worked perfectly fine!!
Cheers mate!
Forum|alt.badge.img+7
I noticed that I regularly kept comming back to this question because of the provided code by @david_r.
I figured there probably are more people using this code so I converted it to a custom transformer:
https://hub.safe.com/transformers/stringcleaner
  • October 5, 2016
Cool! Thanks for making it available to us all.
  • October 25, 2018
Does jeroenstiers have any plans to upgrade the "stringcleaner" custom transformer to Python 3.4? I'm using "stringcleaner" to clean Non-HTML characters (&, <, >, ") from the JSON data that I am reading before writing out to an AGOL feature layer. It works very well. Thanks for "stringcleaner" custome transformer. Otherwise, my data would fail writing to AGOL.
  • October 26, 2018
Here's the same code updated for Python 3.6, @jeroenstiers
import fmeobjects
    desc = ud.name(char)
    if cutoff != -1:
            if value:
                value = str(value)
  • October 26, 2018
import fmeobjects
    if cutoff != -1:
            if value:
                value = str(value)
Thanks for updating the code to Python 3.6. I'll put it to good use. @blucas
philippeb
Forum|alt.badge.img+22
  • October 26, 2018
Use the StringPairReplacer and paste this string below into the Replacement Pairs parameter.
Create a custom transformer and use it easily in any workbench. I've created the AccentRemover just like that :D
It's only good for french though...
à a À A â a Â A ç c Ç C é e É E è e È E ê e Ê E ë e Ë E î i Î I ï i Ï I ô o Ô O ù u Ù U û u Û U ü u Ü U
  • October 26, 2018
I agree, it's a very nice solution if you know beforehand all the possible accents that you want to get rid of.
  • October 26, 2018
Oh, and by the way, if you wanted to keep it 7-bit safe, then I think you forgot the oe-ligature ;-)
jackyd
Forum|alt.badge.img+16
  • June 28, 2022
HI David,
The download file no longer appears to available.
I tried the code above up I can't get it to work, and my python isn't strong enough to see where i have gone wrong. It runs but doesn't to remove the accents :(
Here is a screen shot of my python caller
accent remover python caller screen shot
  • June 29, 2022
HI David,
Try using the StringDiacriticRemover from the FME Hub in stead: https://hub.safe.com/publishers/safe-lab/transformers/stringdiacriticremover
jackyd
  • June 29, 2022
HI David,
Thanks will do :)
