How to fill Published Parameter with Environment Variable? Startup script or something else?
arekpierchala
Hi.
I have to create workspace in FME2015 and I need to fill specified Published Parameter with Environment Variable. How can I do that? Via startup script or something else?
Best answer by david_r
Ah, sorry, I see you wanted it in a parameter.
Try using a scripted parameter. Example returning PATH:
Note that the parameter cannot be published, since it's scripted.
  • August 19, 2016
Try the EnvironmentVariableFetcher
  • August 19, 2016
mark2atsafe
Forum|alt.badge.img+44
  • August 19, 2016
The other thing you should be able to do is use ${variablename}
For example, on my FME I created a user parameter of type text and in the default value entered ${appdata}
A ParameterFetcher returned the value of that as C:\\Users\\imark\\AppData\\Roaming
arekpierchala
  • August 23, 2016
very nice,
thanks, it also works
