Execute transformer once a month
sunsilk11
Hi I have a workspace which does a bunch of queries and inserts and updates an SDE polygon feature class. The workspace is run every 2 minutes.
I have written a shutdown script to rebuilt the indexes using arcpy.RebuildIndexes_management
This command however takes over 2 minutes to run, hence I would like to only run it once a month, say one the first of the month between 12 and 12:30 am.
Any suggestions ?
Could you take the shutdown script out of the workspace and run it in a PythonCaller in a seperate workspace which is scheduled using either FME Server or Task Scheduler?
FME Server offers the ability to run using a CRON time as opposed to a regular timed interval.
parashari
  • August 9, 2019
You can create a batch file of the workbench and run through task scheduler if you are working on Windows OS.
sunsilk11
  • August 9, 2019
Thanks. That's an option. I thought there might be a way to use a testfilter and run a python caller on specific date and time.
Forum|alt.badge.img+32
  • August 9, 2019
You could amend your python script so that it retrieved the date then tested if it was in your range and only completed the rest of the script if it passed
