Is there FME equivalent function like Oracle Decode?
navaneet
Is there any function exists in FEM equivalent to oracle function decode.
DECODE(supplying_code, 1, 'Oracle',
2, 'FME',
3, 'ArcGIS',
'GIS') result
Best answer by david_r
I would say the AttributeValueMapper is the closest equivalent, although you could also get the same results in e.g. an AttributeCreator or AttributeManager using a conditional value.
antoine
Forum|alt.badge.img+5
  • March 5, 2020
  • March 5, 2020
