Hi all
I am trying to compare two databases which contain similar and different geometry files. I am trying to figure out which geometry's are the same and which are unique to each database.
A few big issues I have is the complex of the geometry and even the SAME geometry's has been captured slightly differently; even thou it's of the same area.
I also have no data to help identify which geometry's are the same.
I am currently struggling to figure the best solution to my problem, the geometry can be complex with donuts and multiple areas representing the “same” geometry. I can't find the sweat when I simplify the data enough to get a match and not corrupt the data too much that everything matches.
I have added two SHAPE file, containing 7 Features each, with 6 that should match and 1 that should not.
Any help or ideas would be appreciated
