Httpcaller vs job submitter
arthy
Forum|alt.badge.img+8
Hi all,
I would like to know the pro and cons of using a jobsubmitter instead of a httpcaller in terms of efficiency, parrallelism, ... and vice-versa.
Thanks
  • January 24, 2018
If you mean in the context of possibly using the HTTPCaller to submit a job using the REST API, it's exactly the same. As far as I know the FMEServerJobSubmitter uses the exact same API.
I believe so. If you want to call the data streaming or download services you can use the HTTPCaller and DirectURL.
Some info on the FMEServerJobSubmitter behaviour is available here: https://knowledge.safe.com/articles/55369/fme-server-troublshooting-fmeserverjobsubmitter.html
Calling jobs (job submitter) through REST API is available here: https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/transformations
