python caller with three arguments
  • February 18, 2020
  • 11 views
Hello!
I would like to calculate the difference of z value between two neighboor points in the following way:
- test if the extreme_ is LOKMIN
- if it is LOKMIN , then take the two neighbor value (the points are sorted), take the higher (so the bigger number) and exract them each other.
Here is my attempt:
import fme
import fmeobjects
from functools import reduce
from math import sin, pi
def left_slope(feature_a, feature_b, feature_c):
    a_x = float(feature_a.getAttribute('z_uj'))
    a_sz = feature_a.getAttribute('_szelsoertek')
    b_x = float(feature_b.getAttribute('z_uj'))
    b_sz= feature_b.getAttribute('_szelsoertek')
    c_x = float(feature_c.getAttribute('z_uj'))
    if b_sz == "LOKMIN":
        k = c_x - a_x
        #_nyomvalyu = b_x - a_x
        feature_b.setAttribute('_nyomvalyu', k)
    return feature_a
    return feature_c
class FeatureProcessor(object):
    def __init__(self):
        self.features = []
    def input(self,feature):
        self.features.append(feature)
    def close(self):
        reduce(left_slope, self.features)
        for feature in self.features:
            self.pyoutput(feature)
But it gives an error, can you help me?
Python Exception <TypeError>: left_slope() takes exactly 3 arguments (2 given)
Traceback (most recent call last):
  File "<string>", line 24in close
TypeError: left_slope() takes exactly 3 arguments (2 given)
PythonCaller_5(PythonFactory): PythonFactory failed to close properly
PythonCaller_5(PythonFactory): A fatal error has occurred. Check the logfile above for details
Best answer by paalped
Here is a quick  solution to Your question:
import fme
import fmeobjects
def mid(feature_a, feature_b, feature_c):
    b_sz = feature_b.getAttribute('_szelsoertek')
        k = c_x - a_x
    def __init__(self):
        self.features = []
    def close(self):
        end_index = len(self.features)
        num_args = 3
        for i in range(end_index - num_args):
            mid(*self.features[i:i+num_args])
becchr
Forum|alt.badge.img+25
  • February 18, 2020
hi @gylona, if i understand well what you try to do, i think you can avoid python by using the 'adjacent feature attributes' possibilities of FME?
https://www.safe.com/blog/2017/08/adjacentfeatureattributes-evangelist166/
  • February 18, 2020
The function left_slope passed to reduce() should only have two parameters. Check the documentation to reduce(): https://docs.python.org/3/library/functools.html#functools.reduce
A more general comment: you have two consecutive return statements (lines 15 and 16), but only the first will ever be executed. If you need to return both feature_a and feature_c, do (if reduce allows it):
return feature_a, feature_c
paalped
Forum|alt.badge.img+5
  • February 19, 2020
import fme
import fmeobjects
        k = c_x - a_x
    def __init__(self):
        self.features = []
    def close(self):
        num_args = 3
paalped
  • February 19, 2020
import fme
import fmeobjects
        k = c_x - a_x
    def __init__(self):
        self.features = []
    def close(self):
        num_args = 3
A better less memory intensive way would be to:
import fme
import fmeobjects
        k = c_x - a_x
    def __init__(self):
        self.container = []
        self.max_items = 3
        if len(self.container) < self.max_items:
            self.container.append(feature)
        else:
            mid(*self.container)
            temp = self.container.pop(0)
            feature = temp
    def close(self):
        for feature in self.container:
