ArcGIS Portal Feature Writer - With Editor Tracking Disabled - Still overwrites
  • October 20, 2021
  • 46 views
tiztrain
Forum|alt.badge.img+3
Hey all,
I am using the ArcGIS Portal Feature Writer and when I push my edits to a feature service, it overwrites the editor tacking fields (eg. createdby, createddate, modifiedby, lastmodifieddate) with my username and today's date and time of upload, instead of values I have prepopulated.
The table sits in a postgres database and I have turned editor tracking off against that table.
Is it possible to push data using the FME writer without those values getting automatically populated?
runneals
Forum|alt.badge.img+19
  • October 27, 2021
This is done on the ArcGIS Online side and it will require you to download the data, update the fields, reupload it, and enable editor tracking again. Take a look at this article from esri that talks about how to make edits to edit tracking fields: https://support.esri.com/en/technical-article/000025504
