We are using collector for ArcGIS to edit assets with a GPS unit to portal hosted feature services to sub-foot accuracy. We also have corresponding production feature classes in a SQL server sde of networked water assets that is the system of record for attribution. I have a workspace that will update changes in attribution from our production sde database (SQL server) to attribution in a portal hosted feature services that has editor tracking enabled. I want to maintain the last editor and last edit date fields in collector that is done by the field staff. When a feature is update by the workspace, it is overwritten to the run date and time and with my name as the editor. I was wondering if there is a way to use python caller to disable and enable editor tracking at the beginning and end of the workspace. I am not very python savvy, so any help in this regard will be appreciated. If there is another way other than python caller I am interested in that also.
