Why FME has stopped working when Parallel Processing is enabled on Custom Transformer?
  • July 22, 2021
  • 51 views
sashal
Forum|alt.badge.img+8
My workbench run successfully but when I enable parallel processing on a custom transformer, and 'FME has stopped working' error/APPCRASH occurs.
I have tried:
  1. using only one group to process to rule out having too many parallel processes,
  2. I have tried setting to minimum, moderate processing.
  3. I have tried publishing to FME server and running.
All fail as long as parallel processing is enabled on the custom transformer. Does anyone know the solution for this?
virtualcitymatt
Forum|alt.badge.img+34
Could be a number of things, you will need to try and pin point the place where the crash is happening. The log file should help a little here.
Something to note, when parallel processing like this FME first has to write out the data to temp. The data is then read by a new process from the temp location. Is your system funning low of space? This could effect the process.
