Hello community!
I have 7 Batches (created via Batch deploy), that read spatial data from an oracle 10 database into SQLite. The biggest user takes, when batch is started manually, about 18 minutes. When this batch is started using windows scheduler, it takes up to 3 hours! Same for all the others.
I'm using FME 2013 SP1 Oracle Edition on Windows Server 2012.
neither the oracle server nor the fme server is under heavy load. (1-5% cpu).
scheduled task are started as same user which starts manually the batches.
(admin, highest privileges). Is there an option to tell each task its priority?
is there a problem when batchfiles and tclfiles are located on desktop?
(workspace are located in user\\documents\\my fme workspaces)
would be thankful for any advice.
best regards, chris.
