Rejected Feature Handling on FME Server
I am noticing that even if I set my workspace in Workbench to terminate on rejected features, it runs without error on FME Server. Is the rejected feature handling a workbench-only feature? I am expecting to see the same behavior on FME Server. I'm using 2017.1 in my testing. Thanks.
Best answer by brianatsafe
Happy to announce that this issue has been fixed and will be available in FME 2018.1.
fmelizard
Forum|alt.badge.img+17
  • March 5, 2018
Hi @dbaldacchino,
It should be the same as whats set in the workspace. Can I ask which transformer(s) you are seeing the wrong behaviour in?
Hi @MattAtSafe,
I'm using an HTTPcaller. The workspace terminates in workbench but not on FME Server (I have to add a terminator to get the expected behavior on FME Server).
fmelizard
  • March 5, 2018
dbaldacchino wrote:
Hi @MattAtSafe,
Hi @dbaldacchino,
Thanks I've taken a look into the system and it seem like this is a know issue for the HTTPCaller (and some JSON transformers). I have linked this Question to the internal prblem report. Thanks for sharing your worksaounrd and I'm sorry for the inconvenience this bug may have caused.
fmelizard wrote:
Hi @dbaldacchino,
Thanks for confirming @MattAtSafe, very much appreciated!
brianatsafe
Forum|alt.badge.img+11
  • June 29, 2018
