I am a bit of a novice but I can extract a value from the block, change the type from text to numeric ( tried both types) but scaler stops processing at the Scaler transformer. If I add a value for the scale or IF I use AttributeCreator and put a value in as an attribute it will pass that hand value thru Scaler. I need to have Scaler read the value from the North Arrow block and scale the entire drawing accordingly. What am I missing?
Scaler: Issue - I can not scale AutoCAD dwgs using attribute found in North Arrow and Scale Block. How do you get Scaler to accept an attribute from a dwg to use as the scale value?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
