Custom transformation issue
oscard
Forum|alt.badge.img+21
Hi.
I have defined a custom transformation in the file "MyCoordsSysDefs.fme":
XFORM_DEF Test \\
SRC_DTM ED50 \\
TRG_DTM ETRS89 \\
DESC_NM "7 parametros" \\
GROUP "Custom" \\
INVERSE Yes \\
MAX_ITR 8 \\
CNVRG_VAL 1e-09 \\
ERROR_VAL 1e-06 \\
METHOD 7PARAMETER \\
DELTA_X -130.5090 \\
DELTA_Y -89.9490 \\
DELTA_Z -145.9030 \\
BWSCALE 5.2690 \\
ROT_X 3.1126 \\
ROT_Y -0.4718 \\
ROT_Z 3.3181
How can I tell FME to use this transformation instead of the default one?
Thanks for any help provided.
Best answer by jeroenstiers
Hi @oscard
Maybe the CsmapReprojector allows you to pick your custom transformation?
Forum|alt.badge.img+7
  • March 24, 2017
Hi @oscard
oscard
  • March 24, 2017
jeroenstiers wrote:
Hi @oscard
Thank you!
I knew the Reprojector transformer, but I had no idea about the CsmapReprojector one.
itay
Forum|alt.badge.img+17
  • March 24, 2017
Hi @oscard,
According to the documentation you must restart the Workbench application to make it visible in the coordinate system gallery.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/coordinate_sys_custom_about.htm
any chance you missed out on that?
oscard
  • March 24, 2017
itay wrote:
Hi @oscard,
Thanks for the answer! But that wasn't the problem.
It's a custom coordinate transformation, not a custom coordinate system.
itay
  • March 24, 2017
oops...more coffee!
